AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Layer error, i cant create new or modify layers
3 REPLIES 3
Dan_Fine
324 Views, 3 Replies
i cant modify or create new layers. i get the error messege and it tells me to enable the JIT debugger.this is the messege
"To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Can anyone help me fix this problem??
3 REPLIES 3
in reply to: Dan_Fine
Try a repair reinstall of LT. Here are some topics if you
want to browse other ideas:
http://discussion.autodesk.com/search.jspa?numResults=25&inputEntered=true&source=forumlist%7C8&q=%28JIT%29+debugging&objID=c8&search.x=12&search.y=9
http://search.yahoo.com/search?p=(JIT)+debugging&fr=ieas
Dan_Fine
I have the educational version, does this make a difference?? what is the difference between a reinstall and a repair install?? will i loose any files by removing autocadd?? Message was edited by: Dan_Fine
Charles_Shade
You may lose any modifications you have made but you will not lose the CAD files. They should be stored in your My Documents or some other folder that will not be overwritten or replaced withe the reinstall. Templates though would be another matter and you should probably copy custom template to a My Documents folder.
If you start the AutoCAD disk it should give you the option to repair install as well as remove and then reinstall.
regards,
cshade
”Boost
