Good Morning
Probably an easy question but i am just converting back to AutoCAD from microstation.
I am trying to change the colour of a layer in my viewport. Using the layer manager i can do this but i can not get the actual item to change colour. I have checked the vplayermode is 1 and searched around but no luck !!
Does anyone have other ideas ?
Richard
Is the item colour set to 'BYLAYER' or 'BYBLOCK' or is it set to a colour itself?
Is the item in a block? If it is you'll need to go into the block editor "BE" and change the colour there.
Set it to 'BYLAYER' and it should change to the layer colour
Howard Walker
