AutoCAD LT Forum
Launch PDF Reader with AutoCAD LT
7 REPLIES 7
Message 1 of 8
KateMorricalTowne
906 Views, 7 Replies
There *is* a command you can use to launch PDF documents from a button in AutoCAD LT, isn't there? (I do mean "open", in Acrobat Reader or equivalent.)
I know there used to be one, because I have macros that used START to open a PDF file. However, they were built for AutoCAD LT 2007, and START is not a known command in AutoCAD LT 2010.
(This is embarassing for two reasons. First, I wrote the darn thing! Why can't I remember how I did it? And second...this icon should launch the CAD manual....and no one but me has noticed that it's broken. Smiley Sad)
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
7 REPLIES 7
Message 2 of 8
Johneng
in reply to: KateMorricalTowne
Does the ai_STARTAPP Command work for you?
For example
^C^Cai_startapp;"c:/users/John/Documents/AOSRE50300[1].PDF"
Don't forget to use / (slash) instead of \ (backslash) when specifying the path because as you know backslash is used for wait for user input in macros.
Message 3 of 8
pendean
in reply to: Johneng
Missed it by 9-minutes 😞
_ai_startapp is what I use.
Message 4 of 8
KateMorricalTowne
Bingo! But was START ever a valid option? I've been trying to find out, but "START AutoCAD LT command" doesn't exactly generate good search results. 🙂 I seem to remember some sort of switch, but so much has happened between now and when I first wrote the macro that it might as well have been done by somebody else.
Kate Morrical
BIMmuse.com
Message 5 of 8
An LT Unlimited tip; I believe, from a couple years ago:
"Macro revisioning to newer platforms may require that ^R be added to the beginning of the Macro."
(Tough this has nothing to do wih the needed Command. Smiley Wink)
Message 6 of 8
Admittedly I didn't try that one. 🙂
Kate Morrical
BIMmuse.com
Message 7 of 8
pendean
Are you thinking of the START entry in the PGP file? LT OOTB has no entries for it but AutoCAD does.
Message 8 of 8
KateMorricalTowne
in reply to: pendean
Ah yes, entirely possible. At any rate it's close enough to put it in the "solved" category...thanks.
Kate Morrical
BIMmuse.com
”Boost
