This seems like it should be an easy question, but I cannot seem to find the answer anywhere. Is there a plugin or a native tool that I am not aware of that makes adding keyed notes todrawings any easier. Something where (for instance) if I add a numbered block to the drawing, a corresponding item will appear within my title block/legend. Something referencing external files such as a txt or excel would be fine, but my one-off cut and paste method is for the birds!
I believe there is built in functionality for this in MEP, but is there anyway I can add this to LT?
keith
Fields and SSM may be the closest you can get with LT.
Custom Properties can be added to Fields if need be.
LT at 1/5 the cost. They had to drop some convenience.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
