AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
jpeg
1 REPLY 1
Irish2
192 Views, 1 Reply
jpeg
LT 2011- I place a jpeg of a logo on my sheet in model space. Is there any way to manipulate it as in moving it, making it a tad smaller, etc.? Am I able to copy and paste it? Thanks in advance.
1 REPLY 1
drjohn
in reply to: Irish2
There is a variable called IMAGEFRAME that will allow you to turn on and off the frames of an image inserted and allow you to resize it with grips.
Check out HELP for all the modes available and the explanation of them. You will want to turn off the frame at plotting time probably so a setting of 2 (IIRC) should work for you.  It shows the imageframe and allows manipulation but does not print it.
HTH
DJ
”Boost
