AutoCAD LT Forum
Internal Error: !laymgr.cpp@987: elock violation
4 REPLIES 4
kzabba
975 Views, 4 Replies
Whenever I use either of the commands, save as or new file, this message pops up [Internal Error: !laymgr.cpp@987: elock violation] and autocad freezes. I am running AutoCAD LT 2007. There is also a message that says that the program was not installed properly and should be uninstalled then reinstalled. I have done this and it only fixed the problem for half of a day at work. I would appreciate any help,
thanks.
4 REPLIES 4
in reply to: kzabba
You need to uninstall .NET and reinstall it either from the LT CD or
Microsoft's website, then reinstall LT2007.
>>>...it only fixed the problem for half of a day at work...<<<
This is not a good sign, as software does not breakdown on it's own, you
have something else kicking in externally.
Dean Saadallah
http://LTisACAD.blogspot.com
kzabba
in reply to: kzabba
i am currently using .net, then will try installation with the CD. How do i know which .net framework to use? Edited by: kzabba on Jul 29, 2009 2:44 PM
in reply to: kzabba
If I recall, the LT2007 CD contains the one it needs, but you can also grab
the latest from Microsoft's website.
Dean Saadallah
kzabba
in reply to: kzabba
ok, so i used the .net 3.0 framework and it seemed to work then i rebooted. upon restarting i got this message: 'sqldumper library failed initialization. your installation is either corrupt, or has been tampered with. Please unistall then re-run setup to correct this problem.' i don't know what this means, but i will reinstall autocad lt.
The installation worked for autocad lt, but i will see how long this will work today. Edited by: kzabba on Jul 29, 2009 3:07 PM
”Boost
