The Autodesk support center sent me a file download to reinstall my copy of AutoCAD 2009 LT after a computer crash. I have download the file from Autodesk support but it is unreadable by my computer. See the attachment for a screen shot. Is there another program i need to read the AutoCAD installation file?
Has it got ".exe" on the end of the file name? If not do a right click on it and go to rename and put ".exe" on the end of the name ******copy it first incase it doesn't work*************
Do you have a 64 bit OS?
The dowloaded file is for 64 bit operating systems.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
@Lawson2011 wrote:Has it got ".exe" on the end of the file name? If not do a right click on it and go to rename and put ".exe" on the end of the name ******copy it first incase it doesn't work*************
I wouldn't do that right away ... first check to see if it has a .ZIP extension. If so, you should be able to highlight it and see the file inside. That would be the file you want to execute. If it is a zip file and you see the MSI or EXE file inside, just drag it to yer desktop and double click it.
If it doesn't have EXE, MSI or ZIP extension then Lawson is right. Most email systems will blast EXE files in emails so the sender renames then .TXT or something similar. You would then need to rename it at your end but I don't think ADESK would do that typically.
HTH
DJ
Sorry DJ, I'm not that good at explaining things in laymans terms....you're advise is good.....sometimes even in downloads the file extention drops off too.
So what happens when that pop-up shows up and you simply click OPEN? The pop-up is not an error message, it's an INFORMATION message.
What is the full file name, with extension, that you downloaded?
What version of Win7 are you running, 32bit or 64bit?
hi
Would you tell me where to download Autocad 2009 LT files?
My souce cd had crashed,
I need them to rebuld.
thanks & best regards,
Hi paicaso,
I have replied to your question and provided the appropriate download links on your other thread linked here.
