Did you get this issue resolved? I am having the same problem with a new system in my office. I can insert OLE objects and they display and print fine. However; on the new system we just get the white box with file name. Both systems are using LT 2014.
Any assistance would be appreciated.
Thanks ...
@pendean wrote:
Check your process/procedure: a white box with a name usually means it's not a supported file format for that procedure.
I have used the same proceedure, as stated the one system works fine. We are inserting bmp files which evidently is a supported file format. It is just tedious to me (since I have to insert all bmp files) because my system can and the other system can't.
Any further input would be appreciated.
Thanks ...
