AutoCAD LT Forum
Insert ole Excel table using script & control height, width & aspect ratio
5 REPLIES 5
BWYarger
676 Views, 5 Replies
Brad
LT, C3D 2005 - 2024
Windows XP, Vista, 7, 10, 11
5 REPLIES 5
BWYarger
in reply to: BWYarger
(Sorry about the blank post.  I hit enter twice to exit the subject line.)
I need to insert an Excel table in to LT.  I can paste it, but I need to be able to control the height, width and aspect ratio within the script, so it basically needs to be something I can do from the command line and not involve picking the properties palette and changing the items there.  I suspect there are variables I can control from the command line with the table selected, but I can't find any information on them.
Brad
LT 2011 - 2014
Brad
LT, C3D 2005 - 2024
pendean
Can you do it from the commandline right now?
There are no new OLE variables, OLEFRAME, OLEHIDE and OLELINKS are it.
BWYarger
in reply to: pendean
I don't know how or if it can be done, but I spent an hour or so going through help and checking the web for ideas.  What I can do is specify the ole font, ole point size, and the text height but all of these are done through a dialog box and not the command line.  I don't see a way to edit these inside a script and was hoping someone could provide a way.
Can it be done in full AutoCAD, or are full and LT similar in this area?
Brad
LT, C3D 2005 - 2024
pendean
AFAIK both programs are identically limited: try the customization forums for possible AutoCAD enhanced programming functionality.
Albert_Rius
Hi Brad,
With LT, the properties that you want to modify are only accesible manually via the properties palette. If you can manage to move to full AutoCAD, via Lisp or other customizations you can manage to automatically modify this information.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
”Boost
