Yes.......
I managed to get a picture in a dwg. It worked using printscreen and CTRL-C. If you want to get a particular piece of a picture, you need to use Windows PAINT. Then select a section and CTRL-C.
Quality drops miles down, but it works. Also, tour printer/plotter needs to be pretty recent. Uors is 10+ years, so I only got it an PDF.
I used it in ACLT 2007 and I mailed the drawing contioning the picture. The reciever plotted this drawing using ACAD 2004 (NOT LT) and I got a copy on paper. Like I said, quality is acceptabel.
Good luck
