I have exported a drawing of a detail from sketchup as a pdf and then imported that file into my CAD drawing. It's quite amazing that the line quality of this drawing is good. (I have no idea why). The problem I am having is that when I import the pdf the edge of the pdf shows up as a line and interfers with the drawing which is otherwise transparent. (again I have no idea how or why). I would like to make that line go away and only have the sketchup drawing image. Is there a way to do that in AutoCAD LT 2013? I know you can do this with viewport lines but that may be unique. I have attached the pdf I am using.
Solved by pendean. Go to Solution.
