Morning all,
Hoping for some suggestions and help please.
I had AutoCad LT 2016 on my company laptop which I had set up just how I wanted it in model space, all the menus and tool bars where I wanted them.
My company upgraded me to AutoCad LT 2017 on a new laptop.
Is there any way to import my personalised workspace layout from 2016 to 2017?
I have an AutoDesk 360 membership.
Any suggestions please let me know.
Thank you
Jimmy
Solved by john.vellek. Go to Solution.
Solved by hwalker. Go to Solution.
Welcome to the Forums
In Windows go to the AUTODESK section. In there somewhere is a subsection called MIGRATE CUSTOM SETTINGS.
You can use that to export your settings and import them as well
Howard Walker
Thank you for replying though I am still having some issues.
Can you clarify where the Migrate Custom Settings is found? Should I be in AutoCad or just looking in my C drive in windows?
I have found the AutoDesk folder on the C drive but after searching for Migrate Custom Settings no files can be found.
Do I have to be signed into anything?
Thank you
What version of Windows do you have.
Windows 8 and below
Click on START. Then PROGRAMS. Find the AUTODESK one and open it then find MIGRATE CUSTOM SETTINGS.
Windows 10
Click on the Windows Logo. Then ALL APPS. Find the AUTODESK folder and open it
And you can either EXPORT your settings or MIGRATE FROM A PREVIOUS RELEASE
Howard Walker
Thank you, I am getting there.
Both folders where exactly where you said they would be, I have no idea why my original search didn't find them so thank you.
Exported Cad2016 settings off my old windows8 laptop onto a memory stick as a zip file which was the defult option given to me.
My next issue is when I go into my windows10 CA\d2017 and try to migrate from a previous release it comes up with the requirement that it needs AutoCAD LT 2000 or later version to be installed.
Any further suggestions please?
Try the following link
Howard Walker
Hi @Anonymous,
It appears that @hwalker has offered some great help on getting your settings migrated. Here is another article that might help. Please post your results so others might benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
I am checking back to see if my post or @hwalker's helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
