I built a new computer, Windows 8, 64 bit.
Installed Acad LT 2011 64 bit.
Did an export of custom settings from a Windows 7 64 bit LT 2011 installation, imported those to the new Windows 8 LT 2011 installation. This was done using the Start>Programs menu. (I ditched the "Metro" stuff.)
The setup looks mostly the same, but when I go to use it, the icons don't match the commands. I have toolbars down the left and right sides with many icons. The icon for Hatch runs the Polygon command. The Move icon runs the Offset command. Lots of them are screwed up.
The ribbon commands along the top seem to be OK.
Any ideas on how to fix this?
Tks,
GChapp
Solved by gccdesign. Go to Solution.
I found one icon that didn't appear to belong, deleted it, and everything else fell into order.
So my installation is fixed.
GChapp
