AutoCAD LT Forum
Import Ploting style
3 REPLIES 3
kumararik
325 Views, 3 Replies
I'm trying to import a ploting style from one of the drawing to another from my AutoCAD LT 2012.
Cheers.
3 REPLIES 3
pendean
in reply to: kumararik
Is one file STB and the other CTB, is that what you meant? Look up CONVERTPSTYLES command to switch your file between the two.
Or do you want to copy one complete plot setup/paramaters into another file? save pagesetups in the PLOT pop-up in the one file, then import it from the othe file's PLOT pop-up.
kumararik
in reply to: pendean
Hi Dean,
I'm new at this.
I think I want to bring the complete plot setup/parameter to another drawings.
Attached is the what I want to do. Bring plot setup No.1 to match plot setup No.2.
I'm not sure how to do the PLOT pop-up you mentioned below.
Regards.
hwalker
They cannot be done. They are two separate styiles, which is why Dean suggested using 'convertpstyles'
However CTB files and STB files both have a MONOCHROME equivalent, just choose that.
Howard Walker
Left Handed and Proud
”Boost
