The Array dialog box isn’t the only thing you might notice by its absence in AutoCAD 2012. I’ll do a proper “Putting things back to normal” post later, but here’s a quick one for those of you wondering what happened to a few things that appear to be AWOL in 2012.
Are you missing your aerial viewer, blips and/or screen menu? They’re still there, but the commands are undefined. To get them back, just redefine the commands:
REDEFINE DSVIEWER
DSVIEWER
REDEFINE BLIPMODE
BLIPMODE 1
REDEFINE SCREENMENU
SCREENMENU 1
These features are deprecated. That means unless enough of you kick up a fuss about needing them, they are likely to vanish without trace in a release or two.
Edit: Jimmy Bergmark pointed out that the same applies to the TRACE command. If you need it, redefine it.
