AutoCAD LT Forum
I too, cannot see objects that I am moving.
9 REPLIES 9
Message 1 of 10
405 Views, 9 Replies
I recently started a trial for a program called PDF2CAD, the test file I converted worked fine. Everything is selectable and editable. When I move something it does show up while moving/copying. However, when I make additions to the drawing, text for example, and try to move/copy it it does not show up while moving.
PDF2CAD converted the PDF to a DXF format, which I then saved as a DWG.
DRAGMODE - Auto
DRAGP1 - 5000
DRAGP2 - 10
HIGHLIGHT - 1
Tags (2)
9 REPLIES 9
Message 2 of 10
pendean
Hate to say it, but there is nothing wrong with the file: I can grab and move (and see) everything in there.
Message 3 of 10
in reply to: pendean
Have you added something to the drawing, then tried to move what you have added?
Message 4 of 10
Charles_Shade
Message 5 of 10
in reply to: Charles_Shade
Thanks.
Message 6 of 10
I am sorry. I uploaded the wrong file. The one I am having trouble with is the .dxf file that is created using the program on your own computer. I uploaded the one I got from the company that was already in .dwg format. Everything works for that one. It takes 24hrs to get it back though.
Message 7 of 10
Charles_Shade
Ain't that a kicker.
Got it to work but now cannot replicate. There is something off about this file.
AUDIT did return 148 errors but that did not fix it.
Message 8 of 10
maxim_k
Try this file. It appears  DraftSight was able to repair it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 10
in reply to: maxim_k
I will try when I get back to work. Could you tell me what you did in DraftSight to repair the file?
Message 10 of 10
maxim_k
I just opened your DXF in Draftsight and saved in DXF format.
Then I opened resulting DXF in AutoCAD LT and AUDITed it (about 148 errors was fixed), but even without auditing I was able to see newly created objects in this file when I move or copy them.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
