AutoCAD LT Forum
I have 1 drawing that won't plot lineweights
3 REPLIES 3
873 Views, 3 Replies
Hi all. I have LT08 and have one drawing using linestyles and colors to determine lineweight for plotting that just will not plot anything other than a "light" lineweight. I have tried making an all new .cbt, existing .cbt's, changing ALL colors to a heavier weight etc. Nothing is working.
Plot preview is light lineweight, plotting to pdf is light and plotting to the plotter is light. I am not having this problem with any other drawings so there must be something set somewhere in this one file. I did not create the model. Someone else did but I did setup the layout sheet, just like I do other drawings.
Give me a clue as to where to look. Thanks.
3 REPLIES 3
INSERT the one problem file into another that is not a 'problem'.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
mahahaavaahava
are you sure it's not a dwg that's been set up to use NAmed PlotStyles, not Color dependant? Try CONVERTPSTYLES.
/Petri
grantznoble
Had the same problem and it was a simple solution for me.
Check two things:
1: in modelspace with no objects selected, look at your properties window (attached or detached) and you will see the default lineweight. It should be "bylayer". If not, set it to this or everything you create beyond that point won't adopt the lineweight of it's layer (provided you are controlling lineweights by layer).
2: Highlight the objects that are not plotting their proper lineweights. Look at your properties window again, if anything besides "bylayer" shows up in the lineweight box, you won't get the proper lineweights. Choose the "bylayer option for all the objects you want to plot with lineweights from your layer settings.
Worked for me. you may want to change this setting in any custom Templates you have created as well, but that is a different story, for a different thread.
”Boost
