I hate to say it in this day and age, when we expect software to be all
things to all men, but AutoCAD is a tool for producing vector based drawings
not for large amounts of word processored documents, I've found that putting
a lot of text into a drawing, slows the machine down, wacks the file size
up, becomes difficult and slow to edit the more you add. It doesn't seem as
bad if it's all produced in AutoCAD with .shx fonts etc rather than imported
from a word processor. If there's no alternative method of distributing your
Bills of Materials in your contract documents then here are a view thoughts,
if your not doing these already:
Avoid True Type Fonts like the plague. Use .shx fonts.
Would OLE work instead of cut and paste?
If your duplicating any data in AutoCAD, by cutting and pasting across a set
of 'drawings' consider using xrefs. It gets a real headache to ensure every
change to cut and pasted entities or common blocks used across a set of
drawings is carried out, without missing any.
Hope that helps.
Chris Randall
"J Willi" wrote in message
news:0B422E0B753BFF0275AC03225F239533@in.WebX.maYIadrTaRb...
> I am fairly new to Autocad but working hard to learn. My biggest problem
is
> with text... large amounts of text. The drawings I make need to show
large
> bills of materials already produced in Word. I am trying to figure out
how
> to make a simple cut and paste or something similar. The text must be
about
> 12 inches high in the model space with lines and columns separating the
> items. This seems so straight forward in Word and Excel but I can't find
> an efficient way to do it in Autocad LT unless I retype it or import the
> very limited amount allowed in the multitext editor. Am I the first
Autocad
> user to need to import bills of material or am I just not too quick on the
> uptake and missing something really obvious? I really hate to retype
> hundreds of characters that are already produced in an MS Office document.
> Can anyone give me some coaching?
> Many, many thanks!
> cadjim8
