I create a table and wanting to use superscript.
Can someone explain to me?
Solved by hwalker. Go to Solution.
There two ways that I use.
1. Use a font which already has superscript characters in it.
2. Do the following.
Put in the following 3^ then highlight both characters. On the toolbar that is above the text (Table text is always treated as mtext) you will see an icon underlined b over an a. It's called Stack. Click on that and you will get a superscript 3.
The three characters for stacking are
3#4 Creates a diagonal line between the 3 and 4
3/4 Creates a horizontal line between the 3 and 4
3^4 Puts the 3 above the 4 with no line between them
Howard Walker
