hi, i wonder in LT is it possible to create a button so that with a click, i can direct unlock all layers at once?
Solved by AcadAdamLT. Go to Solution.
macro
"-layer;unlock;all;;"
Try that
Ohh wait, skip the "all" command and do a wildcard match instead.
"-layer;unlock;*;;"
Try that, should work.
Edit: Woops, was in abit of a rush, forgot to use the edit reply instead of posting a new one =P
Also, if you need more explanation about creating a macro button you can search it on teh internetz or just ask someone on to forum, off to palma de mallorca for a week, Ciao!
Hopefully OP has already solved this since solution was post 2 - 3 and this was about 1,5 years ago 😉
Works wonderful in unlocking a plan view I have. 5497 objects unlocked so I can make a block now!
@Anonymous,
It appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround? Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
LOOK AT segunopadeji RESPONSE...
i RAN INTO THIS ISSUE AGAIN AND SAW MY FIRST COMMENT! WHAT A LIFESAVER!
Why ask this question.
In LT I Isolate a layer and then hit the unisolate layer after the editing is finished.
The unisolate doesn't work, instead all layers remain locked.
So the real question for me is, how do you get uninsolate to work?
