AutoCAD LT General Discussion
Active Member
fordranger
Message 1 of 6 (269 Views)
How to rotate objects on other axis?
269 Views, 5 Replies
07-09-2004 11:11 AM
I recently purchased AutoCAD 2004 and i am in the process of learning how to use it. One thing i can not figure out is how to Flip a 3D object. It is on the y plane, but i would like it on the x plane.
this is how the object is
x ______
|__ y
how i would like it
x ______
|__ y |______ |
Thank you for your time,
Active Member
fordranger
Message 2 of 6 (269 Views)
Re: How to rotate objects on other axis?
07-09-2004 11:13 AM in reply to: fordranger
error in first post
sorry,
x .......______
|__ y..
how i would like it
x .........______
|__ y ...|______|
*Dean Saadallah
Message 3 of 6 (269 Views)
07-09-2004 04:11 PM in reply to: fordranger
MIRROR command (if you rotate the crosshairs 45 degrees, you will get the verticals). or Copy and Rotate commands. Or, just draw a RECTANG? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Active Member
fordranger
Message 4 of 6 (269 Views)
07-09-2004 06:55 PM in reply to: fordranger
Thanks for the reply but was i typed didn't realy make any sense, ill see if i can clarify in this post.
the pic i attached is the object in "top" oriantation
and in the next post i will attached the object in "front" oriantation
i want the face to look like it is in the "top" but have it in "front" oriantation.
so i want to place the face on a different axis.
and remember i am just learing how to learn this, and do not know that much about this program.
Thank you so much!!!
Active Member
fordranger
Message 5 of 6 (269 Views)
07-09-2004 06:58 PM in reply to: fordranger
In "front" orientation
Distinguished Contributor
derekagar
Message 6 of 6 (269 Views)
07-11-2004 11:59 PM in reply to: fordranger
Are you sure you are in the right discussion group - LT2004 does not do proper 3D.
Are you using AutoCAD2004, if so ask the question in that group and not AutoCADLT2004.
DA
Announcements
Need installation help?
