AutoCAD LT Forum
How to rotate objects on other axis?
5 REPLIES 5
fordranger
491 Views, 5 Replies
I recently purchased AutoCAD 2004 and i am in the process of learning how to use it. One thing i can not figure out is how to Flip a 3D object. It is on the y plane, but i would like it on the x plane.
this is how the object is
x ______
|__ y
how i would like it
x ______
|__ y |______ |
Thank you for your time,
5 REPLIES 5
fordranger
in reply to: fordranger
error in first post
sorry,
x .......______
|__ y..
how i would like it
x .........______
|__ y ...|______|
MIRROR command (if you rotate the crosshairs 45 degrees, you will get the verticals). or Copy and Rotate commands. Or, just draw a RECTANG? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
fordranger
Thanks for the reply but was i typed didn't realy make any sense, ill see if i can clarify in this post.
the pic i attached is the object in "top" oriantation
and in the next post i will attached the object in "front" oriantation
i want the face to look like it is in the "top" but have it in "front" oriantation.
so i want to place the face on a different axis.
and remember i am just learing how to learn this, and do not know that much about this program.
Thank you so much!!!
fordranger
In "front" orientation
derekagar
Are you sure you are in the right discussion group - LT2004 does not do proper 3D.
Are you using AutoCAD2004, if so ask the question in that group and not AutoCADLT2004.
DA
”Boost
