AutoCAD LT General Discussion
Member
kwb3
Message 1 of 3 (136 Views)
How to open AutoCAD Temorary Files?
136 Views, 2 Replies
08-18-2003 09:52 PM
A computer glitch has deleted my AutoCAD file and left only a AutoCAD Temporary File (AC$) titled "save". I can open and view in Autodesk view, but how do I retrieve this into AutoCAD? I'm using LT2001i by the way. Thanks.
*Saadallah, Dean
Message 2 of 3 (136 Views)
Re: How to open AutoCAD Temorary Files?
08-18-2003 10:01 PM in reply to: kwb3
AC$ is not a file you can recover: BAK and SV$ are the only ones that can be
renamed to DWG and accessed, and only if you took the time to turn on BAK
file creation, and setup AutoSAVE respectively.
ISAVEPERCENT=0 and SAVETIME set to 15, plus BAK file creation turned on and
you using SAVE often is the safe way to use AutoCAD.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Member
kwb3
Message 3 of 3 (136 Views)
Re:
08-18-2003 10:06 PM in reply to: kwb3
Cool. Thanks Dean, and a special thanks for your quick reply.
Keith
Post to the Community
New Post
Need installation help?
