Working on an old project in which they've used Autocad to make all the documents, including the documents that contains a s**tload of text that should be excel not Autocad...
For this they have used Mtexts, problem is, when I write my referencenumbers in mtext it turns them into "formulas"
for example: 60/1001 Autocad remakes into 60
1001
How do I get the Mtext not turn my values by default?
Solved by KateMorricalTowne. Go to Solution.
Sounds like AutoStack to the "rescue".
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12545491&linkID=9240817
<3<3<3<3<3<3<3<3<<3<3<3
