You drop the PAT files inside one of LT's search path folders, then in
BHATCH command you can use the custom option to see the patterns defined for
you.
Each pattern needs to be in it's own PAT extension file (one per file), the
PAT file must have the same exact name as the hatch pattern, and there must
be one blank line at the end of each definition inside each PAT file.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
