AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
How to hide or display command names in the Ribbon panels
15 REPLIES 15
Message 1 of 16
2786 Views, 15 Replies
I am learning how to customize the ribbon in LT 2012 and am stumped a to why some of the commands have a name displayed in the panels and some don't. When I select the command in the CUI and check the Properties, there is always a "Command Display Name" listed. Not a big deal but for my sense of symetry I would like to have them all on or all off.
Thanks for any advice on this puzzle.
15 REPLIES 15
Message 2 of 16
Charles_Shade
Custom Panels?
Custom Commands?
All Autodesk Panels and Commands?
Message 3 of 16
pendean
If you only have one command in the Row of that Panel, the image for that command gets larger and it's name shows up.
If the row has two or more comamnds, no name appears.
I guess you could elminiate the COMMAND DISPLAY NAME entry, but I would not recommend it.
Message 4 of 16
in reply to: pendean
I added a few commands to the Modify panel in the Home tab. Move, Copy, Stretch, etc all  have the name of the command beside the button. Offset, Trim, Extend, Break, etc, don't have a name, just a blank space beside the button. I currently have 4 subpanels and 5 rows of commands.
Message 5 of 16
Charles_Shade
Check the particular command that you moved at the Panel and see if the name is there in the CUI.
Message 6 of 16
pendean
Undock your Ribbon, park it in the middle of your screen, widen it. Now what do you see?
Rows, in the primary panel and in sub-panels, need to have more than one command assigned. If you only have one command, you get the name. It's a simple rule.
Since you have the Ribbon on the side you are manually affecting the true display by choking it with the limited width: you must widen the Ribbon to see the actual names/no-names you have, or narrow it to hide the remaining displayed names. Just like Toolpalettes, the narrower they are the more your force the program to hide the true display you have.
Feel free to experiment, keep it undocked and don't get distracted by how you are forcing the program to compensate for lack of space.
Message 7 of 16
in reply to: Charles_Shade
I was checking in the CUI to compare differnces in the commands and noticed that in the Properties section (right lower panel) under Appearance>Button Style it says "SmallWithoutTxt." For the commands that show the name is says "SmallWithText." I changed them all to read 'SmallWithText" and they all appear in the panels.
You can also change the name that appears by typing in a new/altered name on the Command>Command Name line.
Message 8 of 16
pendean
Even better.
Message 9 of 16
Charles_Shade
For so many who look for drawing real estate and efficiency of how many buttons can I put on the Ribbon you are the first I've known to want to loose that space to text.
Message 10 of 16
pendean
25" widescreen, I got plenty 🙂
Message 11 of 16
I don't want to add to the clutter, but just want consistancy. At the very least I would like to label commands that are new to me until I learn to recognize them. And I find the various Layers commands difficult to distinguish.
Message 12 of 16
I am using a 25" MacPro so I have lots of room for displaying buttons. Maybe that is why I am having difficulty with all the hidden and nested commands in the Ribbon. With all of this visual real estate I could display them all!
Message 13 of 16
Charles_Shade
32" Sharp Aquos and 20" Acer Widescreens
(Oh, and I'm 4'3" tall)
Message 14 of 16
pendean
32"? Wow!
I tried dual-screens with (2) 25" widescreens: way too much real-estate to keep track of, I felt like I was watching a tennis match.
Message 15 of 16
Charles_Shade
The acer "looks" about half the size of the Sharp. I keep AdCenter, Properties, and Command line on it so the views are not competing but I understand what you mean.
Although now that I'm getting older the type on the acer seems to keep getting smaller. Maybe two big monitors is not such a bad idea.
AND the Sharp is about 4' away from me on a corner desk so I do not go blind.
Message 16 of 16
pendean
I figured you would be wearing 'shades' (pun intended).
”Boost
