After reinistalling AutoCAD I am trying to clean up the plotter settings and am being plagued by an error message that reads:
PDF995:This plotter configuration cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted.
This message is related to a PDF program called PDF995 that I no longer have.
The first jpg image shows the Page Setup Manager with a current page setup called *A2.0 Arch Site Plan* that I want to delete.
The second jpg shows a PDF Complete printer that I want to delete.
On another error regarding plot styles:
The second jog also shows a plot style table that is missing that I want to delete.
Any page setup with a * you cannot delete as that is linked to the page. If you look at the page tab name you will see it's the same as that page setup.
That plot style is already gone. The only reason why you still see it is because it's linked to the PDF complete page setup
All you need to do to get rid of it is modify your page setup for PDF complete. Choose a new plot style and save the page setup
Looking at your second jpeg again. That PDF complete is a windows printer. You cannot delete it in Autocad. You need to go to control panel and then printers and delete it there.
Howard Walker
