AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
How to check the radius of a polyline arc??
6 REPLIES 6
hgf_21_xy
17593 Views, 6 Replies
Hi Dude,
Can somebody tell me how to check the radius of a polyline arc?
Thanks!
Tags (1)
6 REPLIES 6
Johneng
in reply to: hgf_21_xy
Does your version of LT have the MEASUREGEOM command? If so you can use the radius option of the command or the distance option of the command. Online help for the MEASUREGEOM command can be found at the following link.
http://exchange.autodesk.com/autocadlt/enu/online-help/browse#WS73099cc142f48755-471cc4bd11960d8a16c...
If your version of LT does not have the MEASUREGEOM command you can use the DIST command or the LIST command.
hgf_21_xy
in reply to: Johneng
Hi Johneng,
Thanks to your solutions, and they did answer the question.
But allow me to ask a further question, because this is the one bothers me the most.
Do you actually know how to convert the polyline to the original entities? Because, very often I want to use a 2D DWG drawing that was converted from a 3D drawing, but some lines or arcs are polyline that can not be used directly.
Appreciate your help!
pendean
You can EXPLODE a Pline... .
hgf_21_xy
in reply to: pendean
Pendean,
Thanks for the reply!
However, if I use "explode", the polyline will be exploded to tens of line segments, not a proper line or arc.
pendean
If your PLINE arc is not a true arc, you don't get a true arc ever out of it no matter how hard you try. It has to be drawn correctly first.
What you have is what you asked for, returned a Pline to its true entities.
There are no 2D Plines in 3D, so your original quest is not attainable.
hgf_21_xy
Hi pendean,
From our discussion, it seems the request is simply an impossible one.
Thanks!
-Ken
”Boost
