Hi Dude,
Can somebody tell me how to check the radius of a polyline arc?
Thanks!
Solved by pendean. Go to Solution.
Does your version of LT have the MEASUREGEOM command? If so you can use the radius option of the command or the distance option of the command. Online help for the MEASUREGEOM command can be found at the following link.
If your version of LT does not have the MEASUREGEOM command you can use the DIST command or the LIST command.
Hi Johneng,
Thanks to your solutions, and they did answer the question.
But allow me to ask a further question, because this is the one bothers me the most.
Do you actually know how to convert the polyline to the original entities? Because, very often I want to use a 2D DWG drawing that was converted from a 3D drawing, but some lines or arcs are polyline that can not be used directly.
Appreciate your help!
Pendean,
Thanks for the reply!
However, if I use "explode", the polyline will be exploded to tens of line segments, not a proper line or arc.
