AutoCAD LT Forum
How do you measure (in mm) the length of an arc?
5 REPLIES 5
37505 Views, 5 Replies
I have completed a drawing on AutoCAD LT 2005 and cannot fathom out how to take a measurement of the arc - can anyone help?
I also need to segment the object into 5 equal sections ie a wall - how can I do this?
5 REPLIES 5
DIMARC is a feature of LT2006 and higher:
http://s-www.autodeskpress.com/resources/olcs/acad2006/oct05/topic.aspx
Search around here for a macro for lower versions of LT that kind-of-worked
for many of us before that, if upgrading is not an option.
For any Pro-Users reading this, check our the tip on that page for
AiDimFlipArrow.
Dean Saadallah
http://LTisACAD.blogspot.com
myank
Length of Curve=2 x (pi) x Radius x Delta/360
Can you turn that arc into a polyline and then List it?
Heck I just noticed that highlighting the arc and looking at its properties tells me the arc length, without turning it into a polyline...
...also, look into the Divide command for adding evenly spaced points to a line or arc...
”Boost
