Hello. We currently do not use AutoCAD but are looking to move to AUTOCAD LT from VCADD. We do own a couple of licenses as more and more of our customers communicate to use using autocad files. We have Summa S2 Class D140 printer, and I can't seem to find a way to add them or plot to them. In VCADD I simply point to the IP and off it goes. Can anyone lend assistance?
Solved by pendean. Go to Solution.
Click on Support, and then I assume it's Cutters you want after that.
Howard Walker
Printing in AutoCAD is pretty simple, little different than any other Windows application. If you can't get a Windows driver (which in itself is somewhat astounding...), then you can't print directly to it from *any* application. You could try printing to DWF or PDF, then sending those but again, if there isn't a Windows print driver how would any application print to it?
This is an old post, but I'm quite triggered with the replies. From what I understand the original poster wants to print directly to the cutter. Summa, being quite outdated in the software side, only provide a USB cutter driver not a printer driver which the latter can provide flexibility in using the cutter. The USB cutter driver AFAIK only works with WinPlot software and it is very limited.
