I'm having the same problem. I used several different hatch patterns in my drawing. The text was already there. Some hatching leaves a space around the text and others don't. I'm no CAD brain so I can't have done anything very complicated to get that effect. I've looked at properties, tried deleting hatching and then hatching again. Nothing changes. How can I get a space around my text? I'm using AutoCAD LT 2010.
There could be a chance your text is hovering above the 2D plane of your hatch: Z had a setting in LT just like X and Y.
Post a sample DWG of the issue if you can, or use Properties command after selecting the text and set Z to 0 (regardless of what Properties reports is the setting).
Dean,
I checked properties of text and Z is set at 0. I admit to being a total failure at understanding how the various hatch choices work. I managed to get the hatch on the right side to work after deleting the hatch and then hatching again. Not having any luck with the left side. Appreciate any help!
Jill
Jill, It appears your base building elements are not all on a flat Z=0 plane, so when you draw an outline snapped to corners I am also unable to create a hatch that does not cover the text.
If I draw just a box around the text it hatches just fine. I will try and see if full AutoCAD is able to flatten the file and repost.
Well, thank you very much for your time and effort!
I missed where you also had island detection in BHATCH command se to ignore catching anything, that seems to have fixed it (reset it back to NORMAL).
All I did with this file is use PROPERTIES to select all items and reset Z to 0 for each type (typed it in, not just read it said 0 and left it).
Wow, I'm so close! Ok, I noodled around with Properties and selecting ALL and that didn't seem right. Then, I typed in Properties and selected each kind of hatch in my drawing. I DID see where Island Detection was set to Normal, but there was only X and Y (set to 0), no Z at all.
So, when you state, "All I did with this file is use PROPERTIES to select all items and reset Z to 0 for each type (typed it in, not just read it said 0 and left it).", can you walk me through that so I'll know how to find it next time?
Unlock all of your layers and thaw/on them all.
Select everything on screen.
Open PROPERTIES
At the top, sort by type, select each type of entity.
Most (not all) have a Z entry you can change, regardless of what it reports, select and type 0 (zero).
When done, SAVE your file.
I found that command anybody need contact me in this e-mail
Edited by
Discussion_Admin
Welcome to the forums.
One rule of forums is NEVER post your email address publicly as anyone could use it to send you spam emails
Howard Walker
