AutoCAD LT Forum
help feature defaults to Autodesk Exchange online
16 REPLIES 16
Message 1 of 17
govacj
689 Views, 16 Replies
I have AutoCadLT 2012 and is trying to use the help feature, but it keeps defaulting to the , Autodesk Exchange online. This is a company computer and its not setup to allow the feature.
Is there an offline help feature?
16 REPLIES 16
Message 2 of 17
Charles_Shade
in reply to: govacj
Under OPTIONS in the attached screenshot. Is this where your porgram is pointing to for Help Location?
Message 3 of 17
govacj
in reply to: Charles_Shade
thanks for pointing me there.
But it's not clear as to how to make the change. The options on the right that, ADD, REMOVE or SET CURRENT, are there, but is not in function mode.
Message 4 of 17
Charles_Shade
in reply to: govacj
Click on the File name and then click Browse on the right hand column.
From there you will be able to find the file if it is indeed not pointing to the right place currently.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Message 5 of 17
Kate_LT
in reply to: govacj
If access to Online Help is actually blocked (even with the correct path), you can use an offline version by unchecking the "Access online content" box from the System tab of the Options dialog.
Kate Morrical
Technical Marketing Manager
Autodesk, Inc.
LT Unlimited
Message 6 of 17
Charles_Shade
in reply to: Kate_LT
This is currently checked in my Options, System tab but Help does not default to Online as this would indicate it should.
Message 7 of 17
govacj
This is beginning to be a bit more then I hoped for. I'm assuming that the word file your referring to is , index.html?
Is it possible that the 2012 version is set up to only go online if you click on their help box? The response of my pc to your instruction don't appear to be going in the right direction to default to offline help.
Message 8 of 17
govacj
I think this worked.
I may have created other problem for myself, with changes I made.
I set it to open in pdf format. i get a error message in pdf window.
" There is an error opening this document. The filename directory, directory name or volumn label syntax is incorrect"
ggggrrrr
Message 9 of 17
Charles_Shade
in reply to: govacj
Okay, under the Help Location shown in the Options dialog does your's say:
C:\Program Files\Autodesk\Autodesk LT 2012 - English\Help\Index.html
Message 10 of 17
govacj
Yes...
c:\program files\autodesk\autocad lt 2012 - english\help\indexex.html
Message 11 of 17
Charles_Shade
in reply to: govacj
Is it index.html or indexex.html
(assuming a typo)
And did you try unchecking the button Kate suggested?
Message 12 of 17
drjohn
Strange, Charles, mine has a path of :
C:/Program Files/Autodesk/AutoCAD LT 2012 - English/Help/landing.html
DJ
Message 13 of 17
Charles_Shade
in reply to: drjohn
That will send me to the same place as the index.html does.
Even more interesting there is a file in the folder named junk.html that does the same
(as well as some others - beyond my pay grade or need to know why)
Message 14 of 17
govacj
I did uncheck the box. Its takes me to the right location, I now have an error message that needs to be addressed.
Message 15 of 17
govacj
in reply to: govacj
It's working!
Message 16 of 17
Charles_Shade
in reply to: govacj
Glad to hear.
Any idea of what solution worked for you so that you can check the  Accepted as Solution?
Message 17 of 17
govacj
Located:  Big Red A, upper left (dropdown) > Options (button) > System (tab)
Uncheck box: Access online content....
Select : Default System Browser
This sequence worded for me.
”Boost
