AutoCAD LT Forum
having problems with the erase command
2 REPLIES 2
410 Views, 2 Replies
AutoCad Lt 2004 only lets me select one line at a time when I'm try to pick multiple line to erase. I know you can window crossing but I'm trying to select small object real close to other objects so I do not want to use crossing or a box. In AutoCad Lt 2000 I could type e for erase and pick as many line as I wanted too to erase. I try the same in AutoCad Lt 2004 and it only lets me select one object. Can anyone help me? Nick
2 REPLIES 2
F1 ... Check out the PICKADD variable. ___ "Eric A. Hughes" wrote in message news:41fe6796$1_2@newsprd01... > AutoCad Lt 2004 only lets me select one line at a time when I'm try to > pick > multiple line to erase.
Thank you that worked great! Nick "Paul Turvill" wrote in message news:41fe6dcb_1@newsprd01... > F1 ... Check out the PICKADD variable. > ___ > > "Eric A. Hughes" wrote in message > news:41fe6796$1_2@newsprd01... > > AutoCad Lt 2004 only lets me select one line at a time when I'm try to > > pick > > multiple line to erase. > >
”Boost
