I'd like to add a few stone hatch pattern that I use at work and can not find the location in my laptop. I have AutoCAD LT 2012. Thank you so much.
This is where it is for LT2010
C:\Program Files\AutoCAD LT 2010\UserDataCache\Support\acadlt.pat
also see http://forums.autodesk.com/t5/AutoCAD-LT/Importing-Hatches/m-p/2552416
Hope this helps
Lawson,
I could not do the same you have in yours but the link you provided helped!!!
Thank you so very much.
I have a support folder but since I did not see the other hatches there I though it could not be there but your link said that it can work and it did!
I could give you a hug!
Happy New Year
and many blessings to you.
Not to steal anyone's hug away.... but that's not by default the location of the PAT file AutoCAD/LT uses unless an end user speficcally changed the destination.
For the average user it's buried under your Windows Profile (here for example in Windows 7)
C:\Users\USERNAME\appdata\roaming\autodesk\AutoCAD LT 2012\enu\support\acadlt.pat
Dean,
When I installed LT2010 I left it up to the computer where it put it's info/program files, so that's where it ended up on a Windows 7 64bit...........
KR Lawson
