I am running LT2011 and keep experienceing issues with hatches defaulting to an old layer.
For example if have been hatching a plan and called the hatch layer 'grass' and then move on to hatch walls which i want to hatch in layer 'walls'. Before i hatch the walls i change the layer state to 'walls' and then click on the hatch button. in the hatch creation ribbon the 'by layer' colour dropdown shows the colour for the walls layer yet when i hatch it hatches in the old layer of grass. the only way i seem to be able to get around this is to hatch in the wrong layer and then select the hatch object and change the layer - this is a bit of a headache. this seems to be an intermitant problem; am i doingsomething wrong or is there a glitch??
Solved by pendean. Go to Solution.
