I am having an issue with my hatch tab. When I select it I receive an error "acadlt,pat" can't find file. I have tried many things but can not resolve this issue. I have directed my options, files to look at the folder that contains my hatch files but this did not work. Any other suggestions?
Solved by pendean. Go to Solution.
Did you recently change computers or upgrade and "migrate" from an older LT version? - Yes
Or is this a sudden problem that cropped up today but was working fine yesterday? - This is a new computer and the first time I have tried to use it. Everything else seems to be working except the hatch option.
Your LT version is? 2012
Windows version is? Windows 7 (64 bit)
Are you sure you have an ACADLT.PAT file? Where is it exactly? Can you open it in Windows Notepad and ready hatch pattern names etc.? I can not find the ACADLT.PAT file. Do you know where, by default, it should be located?
