I noticed that the hatch pattern sits in front of the drawing, so I changed the HPDRAWORDER from 3 to 1 and then all the hatching sits at the back where it should be.
My problem is that even though I change it in the current drawing to "1", everytime I start a new drawing this goes back to "3".
I created a template and again changed the draworder from 3 to 1, but once again as soon as I close the drawing it goes back to 3.
How do I get the default to remain at 1 for all drawings?
lennore@outlook.com
Solved by christina.davis. Go to Solution.
sounds like some lisp program does this?
check:-
1) acad.lsp
2) acaddoc.lsp
3) *.mnl
4) appload startup suite
moshe
unfortunately with Autocad Lt 2015 lisp do not work
I guess I will have to type in HPDRAWORDER and change the 3 to a 1, which isn't a big deal, I just thought I should be able to change this once and that would be it.
Thank you for replying
:S
I can reproduce the behavior in the full version of AutoCAD 2015. I think it's a bug.
AutoCAD has always been pretty bad with draw order, which is particularly noticeable with hatches. I don't know how many REGENs I do throughout the day, but it's a lot. Usually a REGEN will fix the draw order problems, but sometimes the drawing has to be closed and reopened to fix it.
no offense but you know you have a dedicated forum for AutoCAD LT
http://forums.autodesk.com/t5/autocad-lt-general-discussion/bd-p/43
Hi Lennore,
HPDRAWORDER is a "Not-Saved" variable (see link below), so, yes, it would need to be changed for each drawing. However, it might save you a few clicks to create a custom button in the CUI that sets HPDRAWORDER to 1. I've linked some videos below that go through the process. The macro you would enter for your new command is: ^C^C_hpdraworder;1;
HPDRAWORDER (System Variable)
http://help.autodesk.com/cloudhelp/2015/ENU/AutoCAD-LT/files/GUID-50DE5CC8-9857-46F1-9374-9F1DA3760D...
How to customize AutoCAD's ribbon and panels | lynda.com
Create a Command Using Autocad macros
Thanks 🙂
funny enough even after typing HPDRAWORDER and changing the variable to '1', I noticed that even then some of the hatch patterns are still at the front. I also clicked on the hatch to back button which i added to the bar, that doesn't work either all the time.
Short of that I print off a pdf, review the print and if needs be i go into the drawing and select everything that is hatched and send them to the back, that definitely works :S
I find a similar problem even a year later. I can't get hatch to draw first at all. Forget about saving settings from one drawing to the next. While in model space, I can not (despite using "draworder" to pull dims forward, "hpdraworder" to push hatch back, or the dialogue boxes to do the same) keep hatch behind dim lines. Pushing hatch back does nothing. Pulling dims forward only works until I zoom, and then hatch is on top again.
This bug is not resolved. I just updated ACAD to 2016, I copied my drawing to a new file, and I've tried everything suggested in the forum.
What I found was that an element of the hatch boundary was not pushed to back, so the hatch would not stay back on a regen. Finding that was chance.
If the video can't keep up, there would simply be a delay?
What I mean by delay would be sluggish video rendering, but I do occasionally see what you are pointing to. I occasionally need to regen to see my change. I would not have thought to blame a graphics driver for such a thing as I would think it is up to the app to que graphics. Beyond my expertise.
I have, however, found this hatch draw order issue again within the same drawing. The issue might be worth thought.
Some allignments will put my leader behind the hatch. Some will bring it to the front. Just by repositioning the leader I get both results, even though the leader is not associated with any element.
Why is VSCURRENT set to "realistic"? 2DWireFrame setting seems to remove any draworder issues I see in your file.
