It depends upon how you specify the hatch boundary. If you use "Pick
Points," then the text is treated as an island, and the hatch should break
around it. If you use "Select Objects," then you may not have also selected
the text object as part of the boundary. In addition, under the Advanced
tab, you must ensure that "Normal" is selected for island detection style.
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
"michael-rra" wrote in message
news:17767002.1096482147118.JavaMail.jive@jiveforum2.autodesk.com...
> According to ACAD 2005 LT help:"if you draw a pie slice, label it with
> text, and hatch it, the "island" of text remains readable."
> This does not seem to happen to me, as my text gets "hatched". The help
> continues, however: "You can override the automatic exclusion of the
> text." Unfortunately, it does not say how the text exclusion can be
> over-ridden (or the reverse). Does anyone have any suggestions?
