Hi All,
When i print multiple pages to PDF the program hangs and becomes unresponsive for about 2 - 3 minutes. If i print a single sheet it is fine.
I am running autocad LT 2014 with service pack 1 installed. The printer is DWG to PDF and i have the Cute PDF printer installed.
Sorry I do mean publish. What I mean by multiple pages is selecting multiple tabs at the bottom (using either shift or ctrl) and then right clicking the tabs and selecting publish.
Background publishing is turned off
If background publishing is off, AutoCAD LT will stay "busy" while it publishes your sheets. Plotting/publishing in the background is what enables you to continue to work while plotting, and not have to wait for the program to finish thinking. Have you tried turning it on? (Although 2-3 minutes of hang time does seem a little excessive.)
Any PDF Underlays involved?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
