I can NOT group anything in ACAD LT 2011. If I hover my curosr over the objects after attempting to group them, they highlight as a group. But, once you try to select them, they select individually.
This defeats the purpose of the command in the first place. I haven't had any recent updates since it last worked properly, so that fault is ruled out.
Please advise.
This is in LT2009 so probably hasn't changed
just type PICKADD at the command line, change it to 1
Howard Walker
What's PICKSTYLE set to?
I had it set to (0). Since you brought it up, I changed it to (1) and that sovled it.
Thanks for your help!! Looks like you got some "stroke" over there with your title. 😉
