(Autocad LT 2014 / Win 😎
STEPS:
Group > Select Ojbects
PROBLEM:
When I go to select the objects as as a SINGLE OBJECT, each object within the group is selectable -- as if they were not grouped.
Shouldn't it be that when I select ANY of the objects within the group ALL OBJECTS in the group get selected, and not just each object?
***** SOLUTION: Set PICKSTYLE to 1 *****
-gxxL
Solved by Charles_Shade. Go to Solution.
Is your PICKSTYLE set to 1?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for the lightning fast response & solution...
...to answer your question, it was not. It is now!
Thanks again!
-- gxxL
That's interesting, Dean. Since I've been with the new office they only use OPENoffice Writer. And that shortcut works in MSWord to make selected text ALL CAPS. However, it doesn't work for Writer.
I know I fat finger my keys from time to time, but that combo seems very unlikely at this office. It's still a possibility though....
