Almost too embarrassed to ask - I've lost my grips, so that when I click on a line I get one grip box at the end of the line. When I click on the box it will only move the line, not stretch.
How do I re-instate grips so I get a box at each end of the line and a handle in the middle so that I can stretch, not move the line.......
I told you it was embarrassing!!
Solved by hwalker. Go to Solution.
I suspect the drawing has corrupted - attached is a small portion of the drawing. Lines are just that, not plines or splines.
Click on any line and a grip appears on only one end. Click on the grip and the line moves instead of stretching......
Just had a look at it and found the solution.
Make the start Z and end Z on everything 0.
Howard Walker
Thanks HW.
This occurred when I tried to flatten everything earlier today. That means I'll have to go over every line (and there are 1000's) and manually reset Z to zero.
Aren't there just times when you hate LT.....
Thanks Dean - don't know why I didn't think of selecting all and removing selection sets. You've saved me an awful lot of work - again.
As for the macro - it's the one that has been posted in the past -
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
I used it on previous versions of LT, but can't seem to get it to on LT2012!
Yeah I did try using the Flatten Macro to start with and nothing happened.
Howard Walker
But that's the weird thing Dean
Both the start and end Z in the drawing he posted are listed as 2.0000E+99
Howard Walker
That would be soooooo nice - any takers?
If I could write macros I'd be straight there, but I can't.....it's like black magic to me!! Respect to those who can.
