I would like to create a block that has an attribute that will always read left to right no matter which method used to rotate the block itself. I know this can be done attaching a rotate parameter to the block and not the attribute, but i want it to also work when using the rotate command.
Post your Block of what you want.
The Dynamic Block Forum is linked in my signature.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
What it is, is a fire alarm horn/strobe symbol. I use the alignment attribute along with an attribute that will promp for a Candela rating when the block is inserted into a drawing. I would like it to be to where the text will always be able to be read left to right no matter how you rotate it.
The Alignment Parameter will always override whatever you do since it affects the entire DynBlk.
Can you live without it?
