AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
functionality oddities of AutoCAD LT BETA (aka 2015)
2 REPLIES 2
ipi
246 Views, 2 Replies
In addition to the ortho function no longer being available in selection commands like CP (crossing poly) or fence, I have discovered 2 more issues:
1. Match Properties cannot be carried between multiple drawing files. In previous releases I would be able to match properties from an entity in one drawing and then toggle between all open drawings and apply that property to entities in each drawing. I can no longer do this reliably.
2. As I toggle between open drawing files using CTRL-TAB and perform a command, say MOVE, I cannot move onto the next drawing unless I move my mouse after the completing the MOVE command.
David Hassan
IP Illustration
www.ipillustration.com
2 REPLIES 2
pendean
in reply to: ipi
Report it to Autodesk, posting here is not the process:
http://usa.autodesk.com/adsk/servlet/item?id=1073063&siteID=123112
and if you are on subscription, do so there too please.
The more that gets reported the more likely it will get addressed.
Are you involved is the beta testing of the first patch for 2015? Get involved if not: http://autodesk.blogs.com/between_the_lines/beta_info/.
Shawn_Niles
in reply to: pendean
I just wanted to confirm Dean's post and stress the importance of reporting any issues you find to the link he shared. All submissions are reviewed so it is much appreciated when customers report the things they are seeing.
Thank you
Shawn Niles
”Boost
