AutoCAD LT General Discussion
jonathan.riouxgervais
Message 1 of 8 (967 Views)
Format menu problem
967 Views, 7 Replies
01-09-2013 10:51 AM
When I click on format in the menu bar, I can only click on layers tool nothing else...
Dont know why!!
Please help me if you know what's the problem :smileyhappy:
The CUI may not have loaded correctly and therefore is causing the issue.
In the upper right of the CUI All Customizations Files window Right click the Red A.
There are options to Restore and Reset the CUI.
And this can be done to your partial CUI's by right clicking on these as well
This may correct the issue for you
Thanks Alumni KateLT:
http://ltunlimited.typepad.com/my_weblog/2010/08/reset-or-restore-a-cui-file.html
Charles_Shade
Message 2 of 8 (955 Views)
Re: Format menu problem
01-09-2013 11:14 AM in reply to: jonathan.riouxgervais
New Problem?
Always been this way?
Customized CUI?
Any other Drop down menus like this?
Registry Cleaner run perhaps?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Message 3 of 8 (949 Views)
01-09-2013 11:15 AM in reply to: Charles_Shade
it's new...
Dont know why maybe i did something wrong but i dont know...
Charles_Shade
Message 4 of 8 (946 Views)
01-09-2013 11:17 AM in reply to: jonathan.riouxgervais
I kept adding to my reply while you were replying.
If a new issue my guess would be a Registry Cleaner run or a change to the computer.
Try a System Restore to a day or three ago.
Message 5 of 8 (943 Views)
01-09-2013 11:23 AM in reply to: Charles_Shade
The dimension menu is the same...
And yes it's a custom CUI but not a custom Menubar. I dont know if It makes a difference?
Charles_Shade
Message 6 of 8 (941 Views)
01-09-2013 11:27 AM in reply to: jonathan.riouxgervais
Message 7 of 8 (932 Views)
01-09-2013 11:57 AM in reply to: Charles_Shade
THANKS A LOT!!
Everything works properly now!
Charles_Shade
Message 8 of 8 (924 Views)
01-09-2013 12:50 PM in reply to: jonathan.riouxgervais
Is there one of the repsonses that can be marked as the Solution incase others have a similar issue?
