AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Fonts
7 REPLIES 7
Message 1 of 8
alex.gotthelf
1460 Views, 7 Replies
Fonts
I can not find my fonts where they are supposed to be and when I add new fonts that I want they don't show up in the list when I want to create a new text style. For example I use Californian as my default font for my drawings.  It works fine.  It seemed to come with the AutoCad LT standard fonts.  But this font does not show up in the fonts path file.
I go to Options and can find the path to fonts but the fonts that show up in my drop down menu when I create a text style are not in that list.  I have dropped new fonts in that file and they too don't show up.  Please help.
ag
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: alex.gotthelf
Have you installed the fonts you need as WINDOWS FONTS?
Go to control panel and then choose Add Fonts
Howard Walker
Left Handed and Proud
Message 3 of 8
pendean
TTF or SHX fonts?
No such thing as a "Californian" font with AutoCAD.
Message 4 of 8
alex.gotthelf
in reply to: pendean
I am not sure if it is true type or shx. Californian is the name like
Arial or New Times Roman. Does Autocad pull from another library of fonts?
*Alex Gotthelf, AIA*
AG Architecture
20 Laurel Hill Road
Mountain Lakes, NJ 07046
(973) 885.7455
ag
Message 5 of 8
alex.gotthelf
in reply to: hwalker
where do you go from Control panel to add fonts? Does AutoCad pull from
the windows font file?
AG Architecture
20 Laurel Hill Road
(973) 885.7455
ag
Message 6 of 8
pendean
SHX fonts belong in the FONTS folder found under your AutoCAD program folder.
TTF fonts must be installed in Windows: Windows' Control Panel has a FONTS app you need to launch, then click in file then INSTALL.
Windows Explorer (not your web browser) will tell you the file type if you go to the folder it is in.
Message 7 of 8
alex.gotthelf
OK. I think that worked. I have it in my list. Thank you.
I still have an open issue on fonts that seems to have been dropped. How
can I get it revisited?
AG Architecture
20 Laurel Hill Road
(973) 885.7455
ag
Message 8 of 8
pendean
Dropped how? if they are correctly installed as I outlined they should all appear: if AutoCAD makes a substitution or you can't see them in any font list then the font(s) is not correctly installed.
”Boost
