I have recieved a survey in DWG format. It has been drawn originally in Turbo CAD. When I try to use it I can not fillet or use the intersect snap. This suggeststo me it is not flat? I have tried AECTOACAD but the problem persists.
Can you Help?
Solved by steven-g. Go to Solution.
Solved by rkmcswain. Go to Solution.
If the FLATTEN command is N/A in LT, you could use the old brute force method of moving the entities to one extreme in the Z direction and then back.
A menu macro that should work in LT can be found here.
