AutoCAD LT Forum
Flashing Menu Icons
3 REPLIES 3
marchitect_nc
493 Views, 3 Replies
Flashing Menu Icons
Wow!! Out of the blue my screen started flashing menu icons after every command except Save. I had two small files open, went from paper space to model space on one of them and BAM! flashing icons and prolonged lag time while the file went from model to paper space. Then after that every command (except Save) evoked some serious lag time and flashing icons.
I'm rebooting after I post this. Hope that clears it up.
Yes I've seen the "flashing" post by others but until now it wasn't affecting my  machine. Now it is here.
Win 7, LT14
m
3 REPLIES 3
Yong.Jing
in reply to: marchitect_nc
Have you updated the graphics drivers?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
No I didnt upgrade any graphics drivers because it had been working just fine. The trigger seemed to be file size. As the drawing file increased in size or if I opened 2 larger projects at the same time then the issue manifested itself.
The LT14 registry fix seems to have cured the problem.
Thanks.
m
Yong.Jing
If the issue still exists, please try the graphics hotfix.
Yong Jing
”Boost
