AutoCAD LT Forum
Fixed plane or lock Z=0 in LT
13 REPLIES 13
Message 1 of 14
apstevenson
15686 Views, 13 Replies
I have a dxf from a survey that has 3 dimensional information, it is of the inside of a room and some of the points are on walls and some on the floor. I want to draw a plan but when I draw from point to point the lines change their Z value. Is there any way to lock the plane that I'm drawing in so that the lines that I draw are 'flat' and on a single plane ie Z=0 but are in line with the points that exist at different heights? I have attached 3 views to show the problem. The 'Top' view is what I'm trying to get, but flat!
Any help greatly appreciated.
Thanks.
Tags (3)
13 REPLIES 13
Message 2 of 14
drjohn
in reply to: apstevenson
There are 2 ways to do that.  Well, maybe 3.
1.  TOOLS >  OPTIONS  and somewhere in there is a Z value setting to ignore the Z value in any pick or something like that.
2.  Select a point that has a true zero value for z and start a PLINE from there. The PLINE will maintain the first Z value selected throughout the command.  fF none have a true zero value then select any point, draw your line and thru the PROPERTIES panel change the zero value of the pline to zero. Be sure to set your precision as high as possible to make sure you don't have a line that is .0000001 in the Z axis. That'll screw it up.
3. Somewhere on this forum someone posted a macro that will run in LT and change the value of all objects in a drawing to zero elevation.
HTH
DJ
Message 3 of 14
hwalker
in reply to: drjohn
And I shall post it again
C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
Even though it was posted ages ago, by a totally different person.
Howard Walker
Left Handed and Proud
Message 4 of 14
apstevenson
in reply to: drjohn
Hi DJ,
Thank you, the polyline solution is very helpful. I've had a look through the options and could not see the option to ignore Z value. If you happen to remember where it is I would be even more grateful than I am already!
Thank you very much.
Message 5 of 14
drjohn
Tools > Options > Drafting tab
Lower left corner has several options for Object Snap Options.  Replace Z value with current elevation is prolly the one you want.
Again, make sure your Z value is set to zero prior to starting the line or pline command.
DJ
Message 6 of 14
Charles_Shade
in reply to: hwalker
...and will be posted again...
it is inevitable...
Message 7 of 14
apstevenson
in reply to: drjohn
Hi DJ,
The only option I have there is 'Ignore hatch objects', is your suggestion for LT (2013)?
I can use your polyline method prefectly well, or indeed the reposted solution which I had come across as I searched the forum for a solution but wasn't looking to flatten the entire thing, just draw on a fixed plane, so thank you for that.
Message 8 of 14
drjohn
@apstevenson wrote:
Hi DJ,
I am looking in full ACAD 2012 ... I wouldn't touch 2013 with a ten foot pole.  But that's a subject for another margarita.
The REPLACE ZERO WITH CURRENT ELEVATION  should be the selection just below the IGNORE HATCH OBJECTS if they haven't screwed that up and changed the dialogue as well in 2013.
Good Luck and Happy Thanksgiving if you are in the USA ... if not, happy whatever today is for you. Smiley Happy
DJ
[edit]
Now that I think about it, that option may not be there in LT since LT does not support 3D.  The pline method is the best I can come up with for now.
[/edit]
Message 9 of 14
pendean
LT has no just 'Z' option, never has.
Message 10 of 14
drjohn
in reply to: pendean
Now there's a news flash.  Smiley Very Happy
Message 11 of 14
pendean
in reply to: drjohn
Since you don't use LT, and I do, your confusing responses needed correction.
Message 12 of 14
drjohn
Apparently it did not confuse the OP.  Smiley Wink
Message 13 of 14
peckdesign
w do i run a macro? or install it?
thanks
Message 14 of 14
pendean
in reply to: peckdesign
Here is one link that may help:
http://www.thecadmasters.com/wordpress/index.php/2011/03/31/autocad-cui-custom-commands/
You can find videos on the same topic for free at youtube.com
”Boost
